Yes, you can put the Leaf into neutral by holding the "shifter" knob in the N position for about 2 seconds (just like the Prius). On the i MiEV, you can do this too, by just "shifting" to the N position.
You can get it into "neutral" immediately by putting it in reverse (if you are going more than 7mph), turns out that works in the prius too. But you have to remember to put it back in "gear" to get regen back.
