Old 02-08-2015, 01:19 AM   #4 (permalink)
stovie
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
Ok, i was looking online at other examples of the vapor setup to see if i could get a better idea of what i was doing wrong and found out that i should first use a glass jar so that i can see whats happening(i was using 2" pvc pipe) so i used a quart jar i had available. I then needed to put something in it to absorb the fuel so that it will create more area for the fuel to evaporate, so i used a wash rag. Then i cut a 1 1/8th inch hole for some 3/4 pvc pipe(out to engine) then another smaller hole for 1/4" dripper hose(in) and put the end of it under the wash rag to reduce splashing in the jar. Then it's just a matter of controlling the air intake valve to adjust the throttle. I got it running really good now!! I need to get the throttle setup for riding, right now i have no way of controlling speed.
