Is the ball valve on the 3/4" side or the 1/4" side? You might want to put a cage around the glass jar so it doesn't get broken. This is a 150cc engine?
From the article; extrapolating up from 4oz of fuel to a gallon is backward; it should be multiple gallons averaged down. However you consume it, calculating mileage is not trivial. It involves headwinds, barometric pressure, etc.
