Old 02-08-2015, 11:28 AM   #1 (permalink)
dcefhatch
Honda HF 8v engine and trans w/ fresh rebuild
I have for sale a D15B6 8v engine w/ transmission and shift linkage for sale.
Engine has a fresh rebuild and has not been started yet. It has new King main and rod bearings. All new gaskets for engine reassembly, with new water pump and timing belt. Pistons have new rings, and all tolerances are in proper spec.
The block was cleaned and painted as you can see in the pictures. Valve cover has been cleaned and paint has been sanded down for a smooth finish.
Comes with intake manifold, exhaust manifold, and alternator.
Transmission is a L3 cable and gear ratios are as follows:
1st: 3.250
2nd: 1.650
3rd: 1.033
4th: 0.823
5th: 0.694
Super long trans for the best economy. This is the engine/trans setup that can get 55mpg right off the bat. Also comes with shift linkage and shifter.
Located in WI
Pictures soon!
