Old 02-10-2015, 06:43 PM   #32 (permalink)
IamIan
IamIan's Avatar
For Fun ... Here's a crazy idea.
BGE Rate Schedule Pdf
Sense you're on 'normal' Schedule 'R' ... which is the same $ rate for electricity no matter what time of day peak or off peak it is ... If you switched to Schedule 'EV' ... Your Peak 'Day' Use rate would increase to double what you pay now ... but your 'off-peak' would be ~38% less than you pay now.
With a ~95% efficient AC-DC charger ... to charge ~95% cycle efficient LiFePO4 battery pack ... pulled out to a ~95% Efficient DC-AC Inverter ... you would loose ~15% of the input AC electricity to cycle efficiency losses.
But ... 38 - 15 = ~23% net reduced electrical cost... for as much or as little kwh of 'off-peak' electricity as you use cycle through .... just don't use those peak 'double' rates.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
