Old 02-11-2015, 05:29 PM   #8 (permalink)
bschloop
sr185 bullet - '81 Yamaha SR185 streamliner
Team Streamliner
90 day: 96.35 mpg (US)
Sunny Colarado - '06 Chevrolet Colarado WT
90 day: 24.18 mpg (US)
cbr250s - '12 Honda cbr250
90 day: 115.29 mpg (US)
Thanks for the plug.
If you plan on removing the foam when you are finished laying up your glass you can just st use polystyrene, and wrap it in a layer of tin foil to protect and release your plug. If you want to use a foam sandwich lamination, I would recommend splurging on the epoxy, and using extruded polystyrene unless you can get the polyurethane that's used in surfboards. You could also laminate the outside with polyester resin over a foil wrapped plug, then add in foam ribs afterward using epoxy. Hope this helps.
BTW, I am planning on making my next fairing set available for purchase as soon as I've finished with developement. As it's designed around the CBR250 it should fit your 125 fine.
