Old 02-13-2015, 11:58 PM   #28 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by stovie View Post
The reason I'm going with this setup is because I've always believed that cars are running way to rich! I've thought for the last 5-10 years that if the fuel requires 14.7-1 a/f ratio at atmospheric pressure then it souls only need about 147-1 at a 10-1 compression ratio do to the reduction in the fuel molecules distance apart. At 10-1 compression ratio and 147-1 a/f ratio the fuel molecules are about as close as they would be at atmospheric pressure. I was able to mess around with my scooter yesterday for about 4-5 hours on 2 ounces of Coleman camping fuel, not sure of its fuel economy yet because I had no way to control it will on it.
Piston engine aircraft are able to adjust the fuel ratio. Best economy is around 16-17:1, if I remember correctly...and at an airspeed not to far above stall. I know a fella on another forum who had a tuner to adjust his Hemi's A/F ratio, and he pushed it to about that point and was getting another 2mpg.
Autospeed article on A/F ratios: AutoSpeed - Tuning Air/Fuel Ratios
Yes, we run 14.7:1 'cuz it's the chemically ideal mixture. True, some sort of by-products go out the pipe at other ratios. From the chart, it looks like running 17:1 (if able) would be about the same amounts as at 14.7:1, as the NOx is on the other side of the peak.
There is a gizmo from Zeitronix that allows mixture adjustment. They recommend you use a wide-band O2 meter with it. (Found it) Zeitronix Zt-3 : Wideband Controller and Datalogging System
