Old 02-14-2015, 06:22 AM   #110 (permalink)
IamIan
IamIan's Avatar
Originally Posted by TurnNBurn View Post
I was looking at getting a Polaron EX charger, which has 4 separate chargers built in, and wiring it like this:
Basically, divide the pack into module groups of 3. Then have a switch where I can engage/disengage the chargers and the battery pack. This way I can have isolated chargers and I can also get them balanced.
Is there a speed advantage to charging 3 packs at a time?
I'd recommend rotating the cells .. instead of diagonal bus bars .. keep the bus bars shorter and more perpendicular to each cell.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
