Old 02-14-2015, 08:56 PM   #18 (permalink)
user removed
Originally Posted by roosterk0031 View Post
Hard to see 2/32 making it 40,000 more miles. Read thru your Malibu history, I got my 03 with 11,000 miles for $9,995, dumped the GM antrfreeze shortly there after, went thru lots of front brake pads as the rotors would rust overnight, finally gave in and replaced the rotors. Had to replace both front wheel bearings as well. Somewhere around 200,000 had to replace the fuel pump and shortly later the idle control valve. Daughter drove off the road 3 miles from home at 265,000 and hit a box culvert sideways and rolled it several times. It was totals, she didn't get scratched.
Fuel history was here and did pretty good, but when retired that info was lost, would be nice if the site would have save it for others reference.
Was pricing tires for the Impala as as much as I'd like to have LLR great tires, at under $60 each I'll probably go Douglas Xtra II again. I have winter tires for it so summer only they'll be good enough.
I've retired close to 20 cars and bikes since joining this site and I can still see the fuel logs. Are mine visible to you?
regards
mech
