Originally Posted by MPaulHolmes
That cable lists one overall shield. I'm no expert .. as I understand signal noise, you are trying to isolate the higher frequency PWM signals so that they are as close to a square wave as possible. The DC on 24V and 5V is likely generated from a switching power supply and could have similar frequencies (depending on the level of filtering).
Our instrument department is *VERY* picky about which cable is installed in our mill. They specify belden cable - I will look it up on Tuesday and post. I'm sure that there is a single shield per pair as well as an overall shield. It is likely more expensive, but having your system work reliably is *PRICELESS*
