Old 02-15-2015, 01:24 PM   #1698 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
I have 7 holes for the wires. Would that need to change? They are all partying in China until the end of the month so they won't get to manufacturing it until then.
The wires would still terminate on the board, so if you need 7, then 7 it remains.
The shields would normally be connected on one end, usually on a single terminal block that is only for analog or digital grounds, which is connected to the negative terminal on the isolated DC output. This can be outside the board, and the connection to the board can be via the DC negative terminal.
I'll run this by our instrument supervisor on Tuesday ... sometimes I mess up the details on the grounds. I don't think you need to modify your board layout.
The Following 2 Users Say Thank You to thingstodo For This Useful Post:
e*clipse (02-15-2015), MPaulHolmes (02-15-2015)
