here is a thread, map is only good for one temperature/rpm basically.
http://ecomodder.com/forum/showthrea...ion-19078.html
per the ultragauge manual load is current airflow/peak airflow (for a given rpm I presume). Mass airflow is a function of a few things, like temperature, not just pressure, as temperature affects density.
