Thread: 0.201 cd Camaro
Old 02-15-2015, 08:20 PM   #11 (permalink)
Cd
Ultimate Fail
Cd's Avatar
This is from the article :
For comparison with our modified Camaro, A2 also tested Dave Matyjasiks closer-to-stock version. Without the grille plug and air dam and with no spoiler but with a lowered ride height and omitted rearview mirrors, the Cd was 0.497. Adding the grille plug and air dam dropped it to 0.337, then a rear spoiler that mimics the one from the HOT ROD Spl. dropped it to 0.292. Meanwhile, tricks on the HRM Spl. got the Cd as low as 0.201. Thats more than a 50 percent improvement from stock, which is enormous.
Read more: Car Aerodynamics - Hot Rod Magazine
Follow us: @HotRodMagazine on Twitter | HotRodMag on Facebook
Top 5 Easy Aero Mods That Almost Always Work
We pressed Eaker to give us clues about simple aero tricks for typical musclecars-stuff that will work nearly every time even without tunnel testing. The delta between Cd numbers is often referred to as "counts," or thousandths of a point, so the difference between a Cd of 0.250 and 0.200 is 50 counts. Eaker gave us some rough estimates on how many counts of Cd you might improve when these mods are applied to a typical older musclecar. Try these next time you're at the track.
Lower the ride height: "Dropping the car-front or rear-will always reduce drag." On our Camaro, raising the tail 1.5 inches changed the Cd from 0.201 to 0.227.Improvement: At least 20 counts per inch
Block the grille: Eaker's tip is "Always get air around the car rather than through it." Stopping air from entering the grille has shown dragstrip e.t. reductions of a tenth or two even on 120-mph cars. This will also reduce front-end lift, and when the front end raises due to lift, drag increases even more. (Bonus tip: Stiff front springs can also help prevent front-end lift). Grille blockage is more effective on older cars than on newer ones with sealed radiator areas, and obviously, it can only be used for short-duration events due to reduced engine cooling.
Improvement: 15 to 30 counts of reduction in Cd and 50 to 100 counts in reduction of Cl
Add a front air dam: "You can usually get 90 percent there just by adding a dam straight down from the front bumper, just like the one on your Camaro." Even Bonneville guys ask us why we have that big barn door on the front of the car, but keeping air out from under the car both reduces drag and neutralizes lift for solid aero gains.
Improvement: 20 counts less drag, 50 less lift. The taller the car sits, the more important the air dam is.
Seal the back of the hood to the cowl: This is another area that's less critical on newer cars that are already well sealed. Cowl-induction hoods have a high-pressure area at the base of the hood. Air does not travel out the back of the hood; it is forced down into the engine compartment. That air must escape through the car, causing flow disruptions and drag.
Improvement: 10-20 counts less drag, 50 to 75 in lift
Remove the outside rearview mirrors: Factory mirrors hanging off the doors are almost always obstacles to airflow. The '94-up Chevy Impalas and Caprices are notable exceptions; on those cars, the Cd actually gets worse when you remove the mirrors.
Improvement: 10 to 20 counts of drag
The Following 4 Users Say Thank You to Cd For This Useful Post:
aerohead (02-18-2015), freebeard (02-15-2015), pgfpro (03-01-2015), Xist (02-16-2015)
