thing to remember is that you are talking to a computer, which can do whatever it wants with the data stream. Open loop might not be a reliable enrichment indicator. Heck unless you tap sensors/injectors directly and feed them into your own computer and calibrate (or really really understand the firmware in your ECU) then there is going to be a lot of guesswork and unknowns.
