Old 02-16-2015, 10:56 AM   #7 (permalink)
jimsiggy
Fiesta - '14 Ford Fiesta Hatch SFE Ecoboost
Team Turbocharged!
90 day: 42.46 mpg (US)
Cruze - '18 Chevy Cruze LT
90 day: 50.23 mpg (US)
Originally Posted by PaleMelanesian View Post
Your scangauge may not show boost but it can tell you what's happening with MAP - manifold pressure. Check it when the engine is off to find what ambient pressure is. 14.5 psi or so is what I see. In a Normally Aspirated car like mine, that ambient pressure is the highest you can get at wide open throttle. If your turbo is boosting, you'll see pressure above ambient on this gauge. 7 psi boost = 21.x psi MAP.
I was thinking along those lines; I will check it out. Scangauge does not provide the (can't remember the terms scangauge uses for setting different parameters other than how it comes from the company) setting params for the 14 fiesta boost readout.
