Old 02-16-2015, 05:48 PM   #1714 (permalink)
e*clipse
Permanent Apprentice
I'm probably paranoid too - exspecially about those intermittent gremlins.
I've been looking for a way to make a faraday cage around normal twisted pair wires. This company sells a ton of different wire looms, some designed for insulating, some designed for EMI shielding, some designed for MIL-spec high temperature, some just designed to look cool...
WireCare.com - Your Cable Management SuperStore!
At a minimum, there are some good ideas for wiring issues we all run into w/ EV's.
- E*clipse
Tesseract over on DIY e cars said some choke style filtering was required on the DC-DC converter which seemed to fix the issue of magic smoke emmiting. I'm unimpressed with EVTV.
Once again, Jhmo, make the wiring as clean as possible because interference gremlins are annoying as all get out to get rid of once you get them. Intermittent gremlins otoh..........impossible.
The Following 3 Users Say Thank You to e*clipse For This Useful Post:
MPaulHolmes (02-16-2015), mpgmike (02-08-2022), thingstodo (02-16-2015)
