Old 02-17-2015, 07:49 AM   #24 (permalink)
ps2fixer
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
Filled up again, scan gauge seems to need a lot of adjustment every fillup. Currently it is at +8% calibration, last fillup it indicated 14.1gal but actual was 14.76gal. I adjusted it to the middle, 14.4, hopefully it it semi accurate.
I turned off the fuel cutoff to 0, maybe I need to adjust it up a little since it probably does cuts the full off between shifts. I don't coast down in gear so I didn't think it would be just a huge effect. Before I disabled it, it was set to 23, I suspect that might be a bit high for the truck.
