02-17-2015, 11:49 AM
#9 (permalink)
Rat Racer
I've seen that before:
KaleCoAuto Radiator Insulator
$22.95
The weakest part of your car is the likely the radiator. It is a simple matter of physics when we tell you this: Energy is lost through heat. Transmissions, as they lose more and more heat, begin to cause more loss of power. However, that's only a small part - The worst part is the radiator! All sorts of heat is lost through the radiator - in essence - losing the horsepower through heat! Not anymore!! KaleCoAuto brings you the Radiator Insulator - Simply slip over your radiator and enjoy the power! KaleCoAuto radiator insulation is made from only the finest asbestos, and is guaranteed to trap 90% more heat!
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
