Originally Posted by cRiPpLe_rOoStEr
I have already seen some folks working around those digital speedometers designed for bicycles (also often called "cyclecomputers") into older cars instead of fixing their stock speedometer. Who needs an all-stock cluster anyways?
So, what are you considering to do regarding the cluster? And is it fitted with a tachometer?
yes it is fitted with a tech. After market. the speedo is the only thing that works right, tried replacing the cluster this weekend with one from the wrecking yard and the new one seemed worse. so now I am going to go all aftermarket.
