Old 02-17-2015, 06:39 PM   #18 (permalink)
cptsideways
Originally Posted by jimsiggy View Post
Thanks for the input.
You know one of the neat things Ford did with this motor, is low friction coatings. This thing coasts in gear almost as well as it coasts in neutral. When I rev the motor out of gear, it takes 6-7 seconds(at least twice as long as a normal motor) or more for the motor to return to idle.
Thats the big flywheel that generates that effect not the low friction stuff. Needed to smooth out the 3 cylinder balance cycles. Also when you lift off your electronic throttle, the motorised throttle plate is held slightly open for emissions reasons.
The clever part about these engines is their ability to run in Lamba under boost conditions, their dynamic compression ratio is also quite high in normal driving giving a high compression ratio over much a greater driving range.
Black Lupo 3L 1.2tdi Manual converted the windsurfing bus!
Kermit the Lupo 3L 1.2 Tdi with a current mpg record of 114mpg (imperial) Now sold
G1 JDM Insight I hate the ride but love the quirkiness
