Old 02-20-2015, 10:34 PM   #7 (permalink)
user removed
The 02 sensor is detecting the massively rich mixture that is fouling the plugs. The ECU is driving the injector duration cycle shorter trying to compensate for the raw fuel being sucked into the mainfold. It would probably run better with a failrly massive vacuum leak. Clamp off the vacuum supply to the fuel pressure regulator and see if it runs better.
regards
mech
California98Civic (02-20-2015)
