Old 02-20-2015, 11:06 PM   #11 (permalink)
user removed
Clamp off the vacuum line to the regulator and see if it runs better. It won't run perfect since the regulator requires vacuum to make it run lean enough but even with that it should run a lot better than with raw fuel running into the manifold.
The plug not fouling worse nearest the regulator could also depend on how close it is to the idle air circuit.
regards
mech
California98Civic (02-22-2015)
