Old 02-22-2015, 12:49 PM   #6 (permalink)
freebeard
Here are the relevant codes regarding stairs.
  • Risers shall not exceed 7¾ inches and the run shall not be less than 10 inches with a ¾ to 1¼ inch nose or an 11 inch tread.
  • Landings at exterior doorways shall not be more than 7 ¾ inches below the top of the threshold
  • Where a stairway of two or fewer risers is located on the exterior side of a door, a landing is not required for the exterior side of the door.
The threshold of the door is 23¼" above the garage floor. The way I'm interpreting the code is that I can have my 2 risers totaling 15½", and then a 7¾" step up through the doorway. Is this interpretation correct?
IMHO, yes. Except that I wouldn't consider that an exterior door. In any case it aligns with the garage door opening, and I see it provides useful storage.
