First power up
I have 60V (just because I have 5 12V batteries that I can use) connected to controller
High V side
Battery pack neg -> precharge resistor (with precharge contactor across it) -> B- on controller
Battery pack pos -> 80 amp DC braker -> primary contactor -> B+ on controller
U,V,W on controller are connected to motor. No overload blocks or contactor.
Low V Side
12V from battery into DC/DC, out as 24V and use the spade connectors into the controller board
+ and - from primary contactor to primary contactor (gigavac)
+ and - from precharge contactor to precharge contactor (gigavac)
serial from connector to USB/serial converter, terminal set for 9600,n,8,1 (is that right?)
Throttle connected to 5K pot (not throttle, since it's hard to hold the throttle in a consistent position)
Turn on 12V. Nothing seems to happen? Well, the DC/DC has a green LED
No lights blink. No serial text on the laptop.
SMOKE! Turn off the 12V into the DC/DC and check. Does the pot need to be at 0 ohms or at 5K on startup? .. the tiny little wires are hot.
Disconnect and check the pot. It still reads 0 - 5K, but the 5V and wiper signals are always the same. And it smells bad. I don't have another handy but a 10K should work, I just won't be able to use full throttle!
Check terminals on the controller for the throttle, so I power up the battery. 4.95V on V+, using GND pin as reference. So far so good. Throttle input pin is 4.75V? Maybe the pin has a pullup resistor? Didi I break something?
Repeat the test with throttle set at half, and after I exchange tx and rx on the cable .. is it tx from the laptop or tx from the controller? Same result - no text on startup. Maybe I have the baud rate wrong? I didn't see a UART setup in the old ACcontroller.c so I'll go look at the new one.
I jumper TX to RX on the cable I made. The laptop echos characters so I think the cable is OK.
I can't think of anything else to check, so I'll take some pictures and post them. Maybe I just missed a couple of steps.
Battery pack with jumpers between batteries
High voltage end, positive DC on the top (red), negative DC (black) with precharge resistor on the contactor, 3 motor phases toward the bottom
Low voltage end, battery with 5A breaker on the left, DC/DC in the middle wired to controller on the right. Contactor cables exit on top and go right. Serial cable plugged into controller board. Throttle pot shown middle bottom.
5 HP, 3 phase, 575V motor with plastic pipe and hose coupler that looks like it will drive the encoder. I need to make a bracket to hold up the encoder, and I need to single condition the encoder output down to 5V.
Reason: Add pictures and descriptions
