Old 02-23-2015, 12:49 AM   #4 (permalink)
Farlander
Water Fuel Designer
You are exactly right on both fronts. You need the P07 for vtec to engage, you would know if it worked because you would feel a distinct drop in power at light load cruising speeds between 45-65 mph at times. You also need the 5-wire air fuel ratio sensor for the d15z1.
The Following User Says Thank You to Farlander For This Useful Post:
Onedopehatch (02-23-2015)
