Old 02-24-2015, 04:47 PM   #27 (permalink)
aerohead
what do you?/can you
Originally Posted by Cd View Post
I'm reviving this long dead thread again in the hopes that you all can translate some of the data presented in the charts.
What do you guys make of this ?
Aero Warriors - The G-Series Wind Tunnel Test Report
A huge amount of data on this site.
Can anyone tell what the original Cd for the '71 Road Runner was ? ( And what they got the Cd down to with the modifications )
And here is the car we are all too familiar with now, tested in the A2 tunnel :
*The first image depicts the different nose configurations.
*The second image is showing front and rear lift for different yaw angles,with the 18-inch nose,with airdam at position-A.
*The 3rd is investigating lift at varying degrees of yaw,with different grille/inlet combinations.
*The 4th is showing the Cd as a function of noses at different angles of yaw.
*As to the Cd of the 'naked' Plymouth,if it is similar to the 1969 car,then Chrysler credited it with 0.35 if I remember correctly.
