Originally Posted by escartiz
I am building a battery pack made of 36 cells in series, nominal is 3.7 per cell but when fully charged at 4.15 as per the spec sheet, I am getting around 150 volts total output. Will the controller be ok with this voltage? I don't want to risk making the final connection. I understand it is rated at 144v and I don't want to damage it. Any advice on this is really appreciated.
My lead pack was above 150 volts just off the charger. No problem ,I think it is the caps that are at risk because they are rated at 200 volts and a spike might go over that.
Alvin
