Old 02-25-2015, 11:13 PM   #15 (permalink)
freebeard
I just found the thread too.
Hey metrompg i think you are right - that tranny is abit too sharp from the topper top to side, next model will be smoother. This is a quick and rough proof of concept for me, thanks for the input. The second one will be way easier!
If you're set on another round, just cut a softer curve in the ribs, position the stringers so there is a continuous 3 or 4 inch gap, roll a roll of flashing metal, cut lengths and roll them (on a cyclone fence or with a skate board in a gutter), then bend it to fit your already-finished frame and rivet or staple it. Or little screws.
Try pulling the rear side tight first and pull the wrinkles toward the front corner.
rumdog (02-28-2015)
