Old 02-27-2015, 01:42 AM   #4 (permalink)
_Turtle_
Stock idle on the hf is 600 rpm. ..2k is extreme high...adjust the idle way down. ..and also check for vacuum leaks. .I have a 87 hf..and am fixing It for mpg...my idle was 1500...fixed 7 vacuum leaks now I idle at 750
Miss: Antenna delete, spare tire and tool delete
To do: Mpguino, warm air intake, full synthetic oil, e3 spark plugs, partial grill block, partial front under belly block
