Old 02-27-2015, 08:12 PM   #10 (permalink)
freebeard
"stockish"
So what is stock-ish? Mild custom? Retro-custom? Low rider?
It would be hard to go wrong with a moderate lowering and Moon hubcaps. If you carry weight a lot, maybe airbags in back with a tank or a compressor. Eventually, maybe a diverter/bellypan/diffuser so all the aerodynamic tricks are on the bottom where no-one will see them.
The tonneau is better than no tonneau. Then a half-tonneau is better and an aerocap is best...-ish. The provided example is a good one. In another thread, someone suggested a half-tonneau that flips from front to back and closes either. The back half closed is most efficient.
