Old 02-27-2015, 09:03 PM   #3 (permalink)
freebeard
Enough madness- hope this hasnt angered you all too much or caused injury by facepalm!
Actually, it's quite entertaining. As of reading this, you have 4 posts. Once you have 5 you can post pictures. The little landscape with a yellow sky will get you an input box.
I took a look at the video. Some of those panel gaps could be tightened up. If the front of the door jamb isn't an exhaust vent, it should be.
Ducting air around internally fails for the skin friction that reduces the volume of air, whereas doing anything effective requires a massive amount of air. The duct needs to be short and open.
jondoeclsm (02-28-2015)
