Originally Posted by renault_megane_dci
I came to the conclusion a N/A engine basically puts out torque based on its capacity.
Namely 25Nm for a 250.
Improving on that is borderline impossible even when you're Honda.
What you can change is :
- coming closer to this target when working on an older engine
- changing the Rpm at which peak torque occurs with influence on power right away.
At the end of the day it's always a compromise on how much you are willing to spend and what you expect from it
You're right.
Honda didn't get more torque from it, actually it was slightly less, but the peak was a bit lower in the rev range.
23.5 Nm @ 8500 rpm vs 23 Nm @ 7500 rpm.
If I could only change one thing on a small single, I'd go for a heavier flywheel, if you could find something that fits.
