Old 03-03-2015, 09:03 PM   #19 (permalink)
sid
grayranger - '10 Ford Ranger XL 2 door supercab
90 day: 30.76 mpg (US)
I don't think the temp sensor is bad. I originally used clear plexiglass behind the grill to block the airflow. Then I took the clear plexiglass off and made a coroplast grill block that mounted outside on top of the grill. During the short time between when I took the plexiglass off and installed the coroplast, the engine temp readings returned to what they were before I added any grill block.
I figured the drop in temperature was either due to less confused air flow or less gas being burned. 8 degrees isn't that much. Something more than 20 degrees I'd be more concerned about.
2010 Ford Ranger, extra cab, 2.3 liter
http://www.stonemarmot.com
Band's latest song/music video "I Sing Along"
The Following User Says Thank You to sid For This Useful Post:
aerohead (03-17-2015)
