Old 03-04-2015, 01:11 AM   #8 (permalink)
MobilOne
Hi Parallelevan,
I didn't communicate very well. What I meant to impart is that using your hands to turn the wheel will give you more information than a torque wrench. You can feel a brake drag. You can feel a c.v. joint click or a drive shaft c.v. joint click. You can feel a dry bearing click. That's what I meant to impart. I didn't mean to imply that you should skip maintenance and inspections. Sorry for the miscommunication.
