Old 03-04-2015, 03:19 AM   #15 (permalink)
lowglider
Diabla - '09 Renault Laguna Hatchback
Guys, since I see you are experienced in this stuff, what do you recommend for treating the fridge`s rubber seals?
For car door seals I usually just clean them up and then treat them with silicone oil, but I do it because I was told to do so and have no data to back it up. And in a fridge every micro hole where air can come in will produce a draft and thus reduce efficiency, so the more flexible the rubber seal, the better.
