Care to explain why you have chosen to limit engine choices to 1 of those 2 listed above? If you are making it all from scratch and plan to use as little steel and as much fiberglass, you could probably make a lean-burn 1.5 Honda fit and still be fun to drive. Or even a mid-sized motorcycle engine 750-900cc could work. It doesn't have to be stupid fast to be fun, especially if you plan on doing more turning than going straight when flipping the "fun switch".
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
