Old 03-07-2015, 03:37 PM   #1753 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
I occasionally had trouble programming the microcontroller when I used the extra cable. It would sometimes only work if I plugged the pickit3 directly into the 6 pins on the board. To do that you would have to remove the enclosure. Make sure you use the new hex file I sent earlier today. I changed the speed to 38.4kbps and 8N1.
kits and boards
