Originally Posted by redpoint5
I've missed a lot of opportunities to ride Lafawnda (my Honda) this mild winter. I promised myself that I wouldn't take her out until I adjusted the valves and put new tires on. The valve adjustment requires cam removal, and I've never gone that deep into an engine before. I'm just procrastinating from the inevitable PITA it's going to be. I once spent 3 hours replacing the cam chain tensioner, which is only held on by 2 visible bolts. I think the tool I made involved masking tape, magnets, swivels, extensions, and the socket and wrench.
Good luck with those valves!
On the SOHC inline 4 it's crazy easy, actually everything seems crazy easy on this thing. On top of that everything seems bulletproof and not prone to needed adjustments. But I did put it off and worked on my camper instead. I did get the sidecovers from the painter back today, so I had to see what those would look like.
