Old 03-11-2015, 08:42 PM   #7 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.26 mpg (US)
I found an LED brake light in the auto section of Walmart. Then I ran a pair of wires to the hot side of one of the rear brake lights and ground.
I ran four wires into the topper. Ground, brake light, 12 volt straight from the battery, and 12 volt switched (on when the ignition is on). I put a four prong SAE connector in the box so I can unplug the topper if I ever take it off. The SAE connector is the flat connector used to connect trailer wiring. Any auto supply store has them.
