Originally Posted by firehawk618
I have searched and searched and am probably missing it.
Can someone explain or post a link to installing a "lean burn" indicator?
Thanks!
You can not simply install one, you would need a jdm 3 stage vtec d15b and wiring and follow the instructions written by a member who has a 4 door green lx.
The best way to see if you are in lean burn is by monitoring the secondary 02 sensor to see when voltage reads 0. You can use a scan gauge or mpguino but it's also easy to tell with a vacuum gauge
I am confused by this statement.
Can you clarify for me?
Thanks!
I wasn't sure what you meant with a CRV with abs and cruise control
