alot of these stoves that are meant to go in a living space ill radiate the heat out in all directions, and if they are designed to be vented directly then you just need to have them within the required range of an outside wall, or find out if you can vent them straight up, pellet stoves and corn stoves often are the same, but you should check to make sure the model you get can burn either, although corn tends to burn dirty so you have to clean the vent more often or it will cause problems, you are also then burning a grain that could be used as a food, where wood pellets can be made from sawdust with the right equipment.
