Old 03-13-2015, 05:15 AM   #46 (permalink)
adam728
adam728's Avatar
Mazda3 - '08 Mazda 3 S
90 day: 29.65 mpg (US)
DR650SE - '13 Suzuki DR650SE
90 day: 46.16 mpg (US)
Wife's - '12 GMC Terrain SLE-2
If you are going to build the engine to be 10:1 compression, then yes, I'd go with what Comp suggested. With iron heads and the low rpm tuning of the TPI manifold that might still be pushing things in terms of detonation at low rpm, high loads.
To run the mpg cam on that link you'd likely want to run compression at no more than 9.0:1.
