Old 03-14-2015, 02:02 PM   #175 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by ME_Andy View Post
You are a mad scientist, my friend. Can you feel me in on the point of the waste solvent? Does it boost the octane so you can run higher compression?
It does boost the octane level for when I'm running mild boost (30lbs or less).
It acts like a water/meth injection type system but injecting a high Toluene based solvent. At this level the pre-heating will be disabled.
The main use will be for FE. I've been doing some testing up to 30% recycle solvent to 70% pump regular gasoline. The cars normal fuel system is running pump gasoline only. The recycled solvent system is a stand alone system because I'm worried about the injector's clogging and also the fuel pump.
Plus the recycled solvent needs pre-heating because of the high Toluene base.
With out heating of the recycled solvent the engine runs rough from fuel fall out.
When I race the car I will remove the recycle solvent fuel cell and cap the lines to pass NHRA's fuel cell rule. I will also be running VP C16 race fuel only and no recycle solvent. This is when I will be running boost around 55psi.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
ME_Andy (03-14-2015)
