the nokian studdable 8 or studless r2? since we get very little snow here i don't know if i can convince her into winter tires. ill look into the synthetic lubricants and switch to ceramic brake pads when the stockers wear out. im wondering about replacing the stock tires since they need to be replaced asap. the stock size is 205/50/17 but im looking at 215/55/17 continental tires with ecoplus. the taller sidewall should lessen the gap between the tire and the fender and ride a tad better, plus less chance of her curbing a wheel and a fractionally higher step in height. nabisco confirms the tires will fit. the (215/55/17)tires are only 5mm wider and 1 pd heavier than stock. but i could also get 205/55/17 michelins(much more expensive) or maybe i should just stick with the stock size.
