Originally Posted by doviatt
You will notice the back window seems to be open or missing in this simulation (no room to roll it down). I would ignore this image as it has many problems.
That is because I removed it from the model.
I was testing whether or not it would be beneficial to have air flow through the cabin and out the back.
I did this test quite some time ago. I'll see if i can find the additional images, as well as any that show the correct pressure.
