I didn't realize that the battery is losing charge because of your driving situation. I thought it was just losing charge from sitting which is why i recmmended a cut off switch to keep it from losing charge. Day time charging could work well I think but not sure of the size and type of panel you'd need to succeed. Even a small one will help a little bit but not sure how worth it it will be if all it gets you is a tiny bit extended range. May just want to get a wall charger and plug it in every couple days when you see the battery voltage dropping too low.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
