Originally Posted by spacemanspif
... One day I'll pull the stock belly pan under the front of the car, rig up a grill block and find a way to secure the pan back up to fix the center sag from broken mounts...Still dreaming up, rear skirts and kamm back...
For working on an '05 Focus grill block, I think it's easier to gain access from the top (having done that myself on my '05). The link below if for an '08, but similar for grill removal. You may also be able to fix the pan sag from above (drill a couple of holes in it, and wire it upward to some of the framework?).
How to Remove 08 Sedan Grille / Headlight - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
I'm interested in what you might come with for rear skirts.
