lotsa ways.
if you zip them up, and they are under 100k then you can attach 'em. if under 1meg you can cheat and rename it to .xls and attach it (and make sure we know the original extension).
if they are seperate files, the upload limit is only per file, so maybe zipping them up individually or pretending they are .xls files will do (or both).
But yah, all the data you got would make the clearest picture.
