Originally Posted by P-hack
here are the output files using xc16 from the original instructables sources, in the latest mplab (on ubuntu).
I had a try at this but received errors during the build. Most likely due to the way i setup MplabX. Until now i have only used the XC8 compiler with my other projects so i may not have added in the XC16 compiler correctly.
Any chance you could post a link to an archive of the project folder? I just want to eliminate the chance that i missed adding a file or put them in the wrong folders.
