Old 03-19-2015, 02:12 PM   #31 (permalink)
EVmetro
Originally Posted by KFM View Post
This is incredible. At every other picture my jaw just dropped at your attention to detail. This is extremely well thought out.
Why did you put both a Wi-Fi and Bluetooth OBDII scanner in the enclosure? Just in case?
Thanks for the good words. It seems like the Androids do a little better on Bluetooth, but Ipads require WIFI. Sometimes I like to use the Ipad, sometimes I like to run an Android (and of course an Android smartwatch), so I just broadcast both. I have a switch to switch my wireless on and off with the key, or to have it stay on all the time. If I leave it on all the time, there is a small drain on the batteries, but it is nice to be able to have a look at things from my living room while the car is in the garage. If I use the on and off via the key feature, I have it set up to keep broadcasting during the charge cycle, but then it shuts down after the charge is complete.
